Rear End Ratio
Rear End Ratio
For those that don’t know. If your rear axle is painted on the DS your gear ratio should be stamped into it.
Rear End ratio.jpg (407.15 KiB) Viewed 12924 times
Frank Sean
Many of the cars also had the ratio crossed out on the GM sticker in the driver’s door jam and an arrow with the GMMG installed ratio written in thin marker. At least Berger #99 did.
Angela Naff
Frank Sean that’s HRE 2000 as well.
